crank seals which ones
Hi everyone the crm rebuild is going to plan but i have a question on crank oil seals on the micro fisch it lists 2 seals for the clutch side a 8mm and a 9mm thick seal but the one i removed was 10mm thick
which one do i fit in its place i have both the 8mm and 9mm thick seals also the athena gasket set has 2 base gaskets which have a a sealing compound on one side do i fit both gaskets ?also which way up does the sealing compound go on the cylinder side or crankcase side
cheers
and a merry christmas to all
cheers
Re: crank seals which ones
Hiya buddy
I'd love to help but I cheated and bought all my stuff from leisure trail , I don't remember seeing two seals on the parts fiche & just ordered the one listed also the oem base gasket doesn't have sealing compound on it & I didn't use it I just oiled the gasket like I always have .
I know not a lot of help sorry but then at least you have a reply !
Ohhh and mines a mk2 btw
Sounds like someone might have sneaked a non OEM seal in there. If the 10 mm worked OK and didn't protrude anywhere the 9mm should be OK.
If possible measure the thickness of the existing base gasket against the new ones.
Those kits are sometimes multi bike generic type kits rather than specific.
+1 to Jompy,
+1 to Jompy,
Eddie Evans
- 2016NWAA
Has anyone got the sizes of the crankseals to hand. I have had a look at the FAQ but could not find them.
I would like to try some Vitron ones.
