oil pump again and im in trouble
Hi Again,firstly thanks for all the previous help i have had but ive messed up big time.I replaced the oil seal on my oil pump but while i had the pump off i dropped it on my garage floor when i put it back on it wouldn't pump properly when i checked the outlet nipple on the pump it snapped off in my hand aarrgghh.Im guessing it got damaged when i dropped it now im realy up poo creek without a paddle,where can i get another pump i could never afford a new one but then i discovered there are none as they are discontinued can anyone help out ?? im going to give it to the engineer where i work to look at but i dont hold out much hope of a fix
Re: oil pump again and im in trouble
Someone said the NSR 125 one may be the same http://www.ebay.co.uk/itm/Honda-NSR125- ... SwPcVVslkZ
Worth a check?
Worth a check?
better pics on this listing http://www.ebay.co.uk/itm/HONDA-NSR125- ... SwI-BWQm7r
Well it looks the same so fingers crossed it is the only concern is the oil delivery will be less as it's a 125 pump but a guy I work with seems to think it's all down to the pump gearing so I hope you will get the oil delivery once fitted to the crm gearing
Good luck buddy , i hope it works out & please let us know how you get on
Check Honda part numbers against each other?
oil pumps start with the same number 15100 but then the numbers are different after that
NSR IS 15100KY4904
CRM IS 15100KAE870
So im guessing they are different i will just use the outlet pipe from the NSR pump if that is the same
NSR IS 15100KY4904
CRM IS 15100KAE870
Here you go but , Honda part numbers explainedwarloks wrote:oil pumps start with the same number 15100 but then the numbers are different after that
NSR IS 15100KY4904
CRM IS 15100KAE870
viewtopic.php?f=6&t=3907&p=23489&hilit= ... ers#p23489
thanks for that info like i said in a previous post the oil delivery may be down to how fast the pump turns by the gearing on the end so fingers crossed the pump should be ok.it does say that the nsr pump also is used on the crm125.has anyone on the site used a nsr pump
Just compared pumps and the nsr125 has a smaller cam which the cable goes around so I've just used the brass outlet to repair my crm pump
Hope you have it sorted
Nice one at least yours is fixed and you know the output is right.
