Indicator dont work
Indicator dont work
In my crm front indicator haven got voltage, bulb is ok, ground of wires also, which one cube response about front position light and flashing, i clean all wires by electrical cleaner and still don' works.
ameadows7
- Bike Owned: 1991 MK2
Re: Indicator dont work
Maybe a bad ground? It happened to me
Ground is ok, i try this ground to another light, it was ok.
- Speeddevice
- Bike Owned: Mk 2
The flasher relay is a small round or square block up near the headlight, about 25 x 25mm. It has a connector with two pins that can easily be unplugged and changed.
Also check the indicator switch as the contacts in there can get dirty or worn.
Have you got a copy of the wiring diagram for testing?
I have checked a black little electronic box responsible for running lights (and flashers), and diagnose was 0 Volt on positive pole
directly on box, i clean everything and no results so i borrow positive pole from rear flasher to have a turn signal (without running light
