CRM250 MKII rebuild data needed
Hi Just about to inspect this motor for a friend. Does anyone have the recommended piston to bore clearances and crank inspection data?
Cheers Andy
Cheers Andy
- nicko
- Bike Owned: Mk3
Re: CRM250 MKII rebuild data needed
I reckon piston/bore clearance is 0.07mm
CRM Mk3, billet clutch basket
The data should be the same as an AR. In which case there is a full maintenance manual in the download section of the FAQs ............
