Help With Honda Engine Oil Seal Identification
Hi,
Bought a job lot of genuine seals and gaskets from a very helpful member to assist with an engine rebuild, found home for most of them but have:
1 x 91203-KAE-003
and 1 x 91201-KAE-003
What do these fit as I can't seem to find a suitable place to fit them?
Advice appreciated.
Thanks,
moleboy
1 x 91203-KAE-003
Advice appreciated.
Thanks,
moleboy
Re: Help With Honda Engine Oil Seal Identification
KAE means they are for the CRM 250.
91201KAE003 is the outside seal for the balance shaft.
91203KAE003 is the generator crank seal.
Both are in the generator crank case side.
Hi KnackeredMk1,
Thanks for the advice, haven't split the engine that far down, so that makes sense now.
David
David
