Mk3 rebuild
Mk3 rebuild
Thought I'd start a build thread it bought a mk3 back in October to use for a bit of laning and a commute a couple of times a week.
I soon found that the previous owner had fiddled a lot and didn't know what he was doing.
Then when my engine begine sounding more like a diesel I decided it was best to go for a rebuild.
But while I was at it I thought I would rebuild the entire bike aswell.
So here it is before the strip down
When I began taking the engine apart I found my piston to have a wear mark
I stripped the complete engine and have split the cases etc this will all be rebuilt over time.
The frame etc will be powder coated.
Re: Mk3 rebuild
PmH first parts are back from the powdercoaters today and here they are
Candy red hubs and yokes
These will be going on a satin black frame
Need some stainless spokes now to lace the hubs upto the gloss black rims.
If anyone knows the best place to get stainless spokes all. Help will be appreciated
Re: Mk3 rebuild
Piston just looks old and rings are obviously worn out - loads of 'blow by'.
Re: Mk3 rebuild
Got my frame back from the powder coaters. Been done in satin black
The crank cases have been glass bead blasted. I'm a little unsure weather to just leave them bear metalwork or if there's something I can do to make sure they stay looking relatively clean
Re: Mk3 rebuild
Looking good. Probably whether the bike is for show, or go will dictate how much work you put into trying to keep a concourse condition.
Re: Mk3 rebuild
It will definatly be used as intended offroad but also hoping to put some supermoto wheels on for the road. I was ju8st wondering if i should coat it or anything to keep the cases in a reasonably clean condition
Re: Mk3 rebuild
Got my wheels put together today. Just need bearings balancing and tyres putting on now
Re: Mk3 rebuild
Tomzed,
Please keep a record of how much everything is costing you, " I am always interested in final costs of a refurb".
Include everything, tyres, valves, rim tapes, price to balance wheels, all powdercoating, every little item adds up. Once you start its like a disease, everything needs painting, plating, coating or replacing.
My guess is that you will not be far off £1,000 on a small refurb.......£2,000 on a full one.
Re: Mk3 rebuild
i will do i expect it will be nearer the second value. all depends on the final finish as im not decided yet on what to do with suspension etc. rebuild to standard or change forks for some off somthing else? or try and have them uprated.
i also want a set of supermoto wheels.
Re: Mk3 rebuild
Powder coat the cases. Much, much, better - cleans with a wipe and won't corrode as the bare ali will do.
Re: Mk3 rebuild
I was going to powdercoating the case but was a little worried it would all chip whilst driving bearings in.
Dropped my suspension off at shocktech today to see what they can do with it.
One of my fork bodies is badly corroded and flaking.
So I was talking to them about using cr forks and if the bottoms arnt the same trying to change them and put the crm ones on.
Does anybody know what year cr forks fit into the crm?
Re: Mk3 rebuild
No need to worry about the engine finish.
Just make sure you use ACF 50 on a regular basis on aluminium, amazing stuff and have been using it for many many years in aviation.
