Welding
- Pie-eyedpiper
- Bike Owned: Mk 2
Welding
I need to weld a nut on the end of my side stand bracket, so the spring won't ping of.
I would be arcing, for that is what I have/do.
Do I need to disconnect my ECU unit to prevent any damage here?
Ta chaps.
Ta chaps.
- 644andy
- Bike Owned: Mk3
Re: Welding
I'd disconnect it, remove it and put it under my bed for safe keeping
Can't be too careful, 5 mins of unplugging may save you a couple of hundred quid and a few weeks off the road.
Whilst it may be OK to weld with the whole system connected it's never worth the risk in my book.
Hanging on for grim death in Hampshire
- Pie-eyedpiper
- Bike Owned: Mk 2
Re: Welding
Thanks for the advice Andy.
A fine idea too.
A fine idea too.
Re: Welding
+1 BUT also encase it in lead, then bubble wrap.644andy wrote:I'd disconnect it, remove it and put it under my bed for safe keeping![]()
Re: Welding
+ 1 fill the bubble wrap with an inert gas.
Re: Welding
+1, then surround the entire area with a rather large fence, with barbed wire along the top. A moat is possible if your bedroom is downstairs
Re: Welding
Make sure you disconnect the alternator, voltage regulator, coil.................everything that has an earth.
I welded a sidestand on a friends GT185 bike a many years ago, the wiring loom melted and nearly caught fire when we pressed the starter button afterwards.
Purely a coincidence you understand.
Re: Welding
Right about now tapping a thread on there is sounding mighty attractive.
- Pie-eyedpiper
- Bike Owned: Mk 2
Re: Welding
Yeah, you know what?
I might shelve the welding bit. Tapping and glueing seems more attractive.
Re: Welding
No contacts with a little gas set?
- Pie-eyedpiper
- Bike Owned: Mk 2
Re: Welding
Not really Mike.
Its not critical anyway. The nut has stayed on wedged against the frame guard, just wanted to make it a bit more permanent.
