Running rich, fouling plug.
- Pie-eyedpiper
- Bike Owned: Mk 2
After a bit of a lay up over winter, my Mk2 is a pig to start and only runs for about 30 secs.
The plug is very wet, and it has always run a bit rich anyway. But it used to run Ok.
What is the best way to lean things off?
Is it best to raise the clip on the needle, or open the air screw slightly?
Any help greatly appreciated.
- pudzie83
- Bike Owned: mk2 1992
Re: Running rich, fouling plug.
fuel,oil,plug change and a good thrashing
usually sorts out a 2stroke coming out of hibernation this will free up clutch plates as well as they stick together over time
Turn off fuel, remove plug and lob in bin,bang bike into 1st gear, push bike around for 5 mins with plug still out and with ignition OFF, bang in a NEW BR8ES, turn on fuel and ignition, choke, kick, ring ding ding ding, ride, enjoy.
Also, put new fuel in. Clean scabby filter, clean scabby pilot jet, and other jets.
FMtB +1 except 3rd or 4th gear.
I found cillit bang and a toothbrush quite good for cleaning carbs and jets believe it or not .... Also, modern fuels with ethanol in them don't have a long shelf life, you'll find new fuel works wonders itself !
Have you forgotten the old advertSpokey wrote:I found cillit bang and a toothbrush quite good for cleaning carbs and jets believe it or not .... Also, modern fuels with ethanol in them don't have a long shelf life, you'll find new fuel works wonders itself !
Yes, some of that cheap own brand label coke also makes excellent parts cleaner.
On visit to Heathrow with a mate who worked there, they were busy in the cockpit of one plane removing a stubborn stain of the windscreen with coca cola
