Brake & clutch levers
muaythaimaniac
Hi all,
Im trying to find some decent priced short levers for my Mk2 CRM... From what I can work out, all the brake levers fitted are the same from Mk1 through to AR but the clutch levers may differ. Is this correct?
If anyone has any specific info regarding levers I would appreciate it
Re: Brake & clutch levers
Post subject: Re: Wanted - Front Master Cylinder
PostPosted: Thu Jan 17, 2013 6:00 pm
Online
I recently purchased a set of these to evaluate their usefulness.
http://www.ebay.co.uk/itm/330802189216? ... 1439.l2648
As you can see they are adjustable. The front brake on my MK3 always felt, studious, now [ in the garage] seems to have more bite. When this cold weather abates I will give it a road test and post up my findings, but that doesn't help you in the short term, they only took 5 days to get here from Hong Kong.
PS, the clutch lever was a poor fit to the perch of the CRM, but it's provenance is dubious. It was however a perfect fit to the TTR, so result there.
_________________
Report this post
I can confirm the front brake lever works a treat, the brake now has real bite.
You may be more lucky with your perch, [see above].
The clutch lever also works a treat on the TTR.
This may be more than you were looking to pay though.
Online
_________________
Report this post
I have these CRM levers £5 each plus postage.
