Front brake slider pin
dazzar250
Post by dazzar250 »
Can any one point me in the right direction for a replacement front brake slider pin is there any on E-bay at the moment, not sure which one I require? On the FAQ it states they are 55mm but this is not stated on the E-bay discriptions. Does the CRM250AR 1998 share the same front brake caliper as any other Honda?
dazzar250
Re: Front brake slider pin
Post by dazzar250 »
Just to add went to replace the front pads and found pin seized, after soaking pin over night, still seized so cut pin in half with a dremel (between the pads i'm replacing any way) then drilled down the center of the pin with small drill bit in dremel this caused the pin to get hot then while still hot got the 5mm alen key and like magic it was finaly free! Yeah it was a long shot if it would work or not, but the pin is no more. Time for a beer to celebrate LOL.
The pins with a hex head on are very good as much easier to get out if they seize.
http://www.ebay.co.uk/itm/Honda-CRM250- ... 232431f9c8
http://www.ebay.co.uk/itm/Rear-brake-Pa ... 2ec0a5074e
If you get away without replacing the rubber boots will have been very lucky as well. I always have a couple hanging in the garage as they seem to fit other brands as well.
Mudfacetony
Bike Owned: Mk2.2, Mk3
Post by Mudfacetony »
fallenmikethebike wrote:http://www.ebay.co.uk/itm/Honda-CRM250- ... 232431f9c8
some gas gas ec models and drz suzukis use the same brakes
http://www.ebay.co.uk/itm/HONDA-CR250-C ... 5ae0a71139
http://www.ebay.co.uk/itm/Stainless-Rea ... 3a7cdf5361
http://www.ebay.co.uk/itm/Stainless-Fro ... 3ccd79d737
the race disc site also does cheap discs
http://www.racediscs.com/index.html
Team Mudface
dazzar250
Post by dazzar250 »
Cheers for the info, hex head type now going to be ordered.
