Chain Slider Washer
badbui
Chain Slider Washer
Post by badbui »
Hi guys I have a mk2 crm250 and have just bought a replacement chain slider.
However I'm missing a plastic washer for mounting it.
I have searched the site and checked the FAQ and have not found any info regarding a part no. for the original part or whether the washer is shared with any other bikes.
Anybody have any clues?
Thanks in advance for any help.
regards
-s
Re: Chain Slider Washer
I don't know of any plastic washers needed to mount any of the chain sliders.
helisupp
Bike Owned: CRM AR (4)
Post by helisupp »
If this is the swingarm chainslider do you mean the steel dished insert , one in top and one in bottom of chain slider to hold it in place using a small phillips screw.....
If so you can buy 52171-KR6-000 (X2)
badbui
Post by badbui »
[quote="helisupp"]If this is the swingarm chainslider do you mean the steel dished insert , one in top and one in bottom of chain slider to hold it in place using a small phillips screw.....
If so you can buy 52171-KR6-000 (X2)[/quote]
Yes this is what I was referring to...sorry for being unclear.
And thank you so much for the prompt responses.
cheers
-sam
