Nearly done
Nearly done
Just thought I would pop up some photos of my AR.
http://i35.photobucket.com/albums/d155/ ... f224b7.jpg
Re: Nearly done
Few more photos of the bike, tried posting this up yesterday using my phone but it all went a bit pete tong
[IMG]http://i35.photobucket.com/albums/d155/ ... f224b7.jpg[/IMG]
[IMG]http://i35.photobucket.com/albums/d155/ ... 3becc4.jpg[/IMG]
[IMG]http://i35.photobucket.com/albums/d155/ ... 4210b0.jpg[/IMG]
[IMG]http://i35.photobucket.com/albums/d155/ ... c75cdf.jpg[/IMG]
[IMG]http://i35.photobucket.com/albums/d155/ ... f4bd96.jpg[/IMG]
[IMG]http://i35.photobucket.com/albums/d155/ ... 7d3f0c.jpg[/IMG]
This is the master cylinder that I am using which was on one of my old bikes
[IMG]http://i35.photobucket.com/albums/d155/ ... d5d350.jpg[/IMG]
I am getting a mate to knock up a spacer and I have ordered a fresh chain as the one that is fitted has more tight spots than a thing that has a load of tight spots in it!!
All the best
Simon
All the best
Simon
- BaNZ
- Bike Owned: CRM250-MK2 '93
Re: Nearly done
I suggest you to install black headlamp plastic, but white rear fender. Or black both.
Is it original AR fork? And what wheels do you have? From what I can see, these seems to be from some CR.
Re: Nearly done
Agree,
This arrived yesterday,
Many thanks to my son, this photo is all over Facebook
Re: Nearly done
The forks are original AR and the wheels are from an XR400
The rear goes straight in, the frot needed an 11mm spacer making up so it was pretty straight forward conversion
- BaNZ
Re: Nearly done
Okay, I see, where did you order wheels?
In my case I need front from CR, rear from XR. Doubt somebody sells such sets, he-he. Gotta figure up something here.
- BaNZ
Re: Nearly done
[quote="Simonypvs"]Agree,
Many thanks to my son, this photo is all over Facebook[/quote]
Oh! Could you, please, make me pictures if this headlight fits on original headlight's mounts?
Something similar comes my way, but with single lens and turn signals.
Re: Nearly done
Got the wheels second hand, they were really cheap. You may need to get them one at a time from eBay or if you want to spend a load of money talon uk can make you a set
Re: Nearly done
I have a question about front wheel. What is the distance between the widest part of the rubber (left or right) and fork legs (the biger pipe). Becouse mine is touching a little when absorb (brake disc side).
