How can I tell if the oil pump is working?
Hi guys
Iv almost got my project crm ready for a test/tuning run before I work on the looks.
One of the things I was wondering is how can I tell if the oil/ fuel mixture pump is working? Iv searched around & I know about checking the setup of it but how can I be sure it's actually injecting oil into the fuel?
The oil sensor is broken so I have no way of telling if the oil is going down yet.
It's running ok, a bit smokey but I'm assuming that's too much fuel which I can sort when I take it for a test run.
Re: How can I tell if the oil pump is working?
pre mix a bit of petrol 1 or 2 liters should be plenty , empty the tank and put the premix in disconnect the twostroke pipe where it enters the inlet, blank the inlet off and fire the bike up , you should get oil coming out of the pipe from the pump once you are happy alls well reconnect the auto lube fill the tank up and away you go
Ah ofcourse! Sounds so obvious when you explained it.
Why didn't I think of that! :-)
Thanks very much
Thanks very much
Way to go Trev
the other way is premix right everytime
I had considered using premix full time, especially since I discovered a broken drive gear for the oil pump. It goes on the inside of the clutch casing.
But from what iv read on the forum it's better to have the pump working instead of premix as you get the right amount of oil depending on throttle position. Is this correct?
If I can't get a new drive gear for the pump I will just go premix anyway.
Adi
Adi
Autolube is better than premix unless you spend most of your time on full throttle - as in competition.
That's what I thought knackered. I just hope I can find the drive gear for the pump!
Thanks again.
Adi
Thanks again.
Adi
69chris
- Bike Owned: mk 2
is it the plastic wheel/cog that fits onto the pump your after or another that drives that ?
you get the right amount of oil with premix as long as you mix it correctly to start withadic3001 wrote: But from what iv read on the forum it's better to have the pump working instead of premix as you get the right amount of oil depending on throttle position. Is this correct?
Adi
69chris its the plastic cog that fits inside the clutch casing. It is for the oil pump but it doesent actually attach to the pump.
Adi
Adi
I'm pretty sure I've got one somewhere ...............
Hi knackered, would you want to sell it? Iv spoken to LT & they said they might be able to get it. Just waiting on a phone call back from them.
Adi
Adi
It'll be FOC if I can find one. Just tell me how many teeth are on it to be sure I've got the right one.
It has 18-19 teeth on it, it's hard to tell as some are broken off! Its the one that has two sets of teeth on it if that helps. The smaller set of teeth has 13 teeth on it?
Thanks for your help as always.
Adi
Adi
