local guys says CRM cylinders cant be rebored?
fishtail
Bike Owned: CRM 250 Mk3
Post by fishtail »
Might be a HK thing?
but I think my bike is actually a Jap import,, ( 96 mk3 )
havent taken the head of yet - just pricing it all up
but he reckons that CRM heads cant be rebored?
is this true of some models?
( if you read my other woes - I might just be after a whole new engine at this rate! )
anyone got any comments?
cheers!
SkidMark
Re: local guys says CRM cylinders cant be rebored?
Post by SkidMark »
AR's have a nicosil coating that has to be redone if rebored but I don't think MK3's have that.
Mk1, 2 & 3 can be rebored as have iron liners. AR is as Skidmark says.
fishtail
Post by fishtail »
thanks for the confirmations!
is there any benefit to taking the bore up the max? - ( was it 67 or 68 mm? ) ( more power? )
I'm going to have a month of doing this I think/hope starting in about 2-3 weeks...
I'm also planning to pop back to the UK in september 8-) probably for 10 days -2 weeks..
( anywhere I can hire a CRM? - would love to do some greenlanes when I'm back!!! - I'll be staying near Donnington ;) )
You can get a bit more power by boring out to 68mm but is it worth loosing the ability to rebore if you have a problem :?: .
Jeram
Post by Jeram »
Just for the record, the AR can be rebored. you send it to a specialist such as Millenium with your new piston.
for 200 dollars plus they will bore it and plate it for you.
For a little extra, eric gore (whom is now part of millenium) will port it for you while its there.
Also for those of you wanting to overbore a steel liner to the maximum but are worried about not being able to overbore further in the future?
There is a very simple fix for this, you simply send your cylinder to millenium again as ask them to bore our your steel cylinder and nikasil it.
In the event of a seizure your bore will be perfectly fine if you run cast pistons, but in the event of a catastrophic failure where the nikasil is chipped or damaged you just box it up and send it straight back to millenium and they will take the nikasil off and reapply it.
Just make sure you get a set of Nikasil friendly rings to put in your piston.
