No spark
Cadiddy
No spark
Post by Cadiddy »
After about 2 years and a complete strip down my CRM is back together (ish) and have been trying to get a spark today with no luck, i've cleaned all the electrical connections whilst the bike was in bits and remade a few dodgy ones. I'm kind of at a loss electrically so any help is much appreciated. oh and the plug, plug cap and ht lead were all replaced.
john7780
Bike Owned: crm 250 mk2
Re: No spark
Post by john7780 »
what mk is it mate?
Cadiddy
Re: No spark
Post by Cadiddy »
Its a mk2
Bike Owned: KTM 200 exc
Re: No spark
Post by back off road »
Does it have the silly side stand switch ?
Jeram
Re: No spark
Post by Jeram »
have you got a good earth?
-the green (earth) wire under the tank that conencts to the frame, isit tensioned up properly, and does it contact the metal (not powdercoat)?
if not earthed properly, you might have enough of an earth to turn the ignition on, but not enough to create a spark
Cadiddy
Re: No spark
Post by Cadiddy »
[quote="back off road"]Does it have the silly side stand switch ?[/quote]
No that was gone before i had the bike
Cadiddy
Re: No spark
Post by Cadiddy »
[quote="Jeram"]have you got a good earth?
if not earthed properly, you might have enough of an earth to turn the ignition on, but not enough to create a spark[/quote]
I will check this and let y'all know.
Thanks for the help already:)
Cadiddy
Re: No spark
Post by Cadiddy »
She's all running now but with a leaky carb so will have it off this afternoon and strip it down, I suspect it's a sticky float needle or something so will report back dreckly:)
Thanks for your help everyone it seems that it was the earth cable not properly earthing
