Wiring Behind Headlight Pictures
HotWired
Bike Owned: CRM250AR
Post by HotWired »
Is someone able to post a picture of how the wiring/plugs behind the headlight and under the speedo should look. It seems to be the only photo I didnt take when disassembling the bike.
Thanks in advance.
Sean
SkidMark
Re: Wiring Behind Headlight Pictures
Post by SkidMark »
you like spaghetti? ;)
what mk do you have? (put it in your sig for easy referance)
HotWired
Post by HotWired »
Sorry mate thought I put the model in the post. It's the AR.
SkidMark
Post by SkidMark »
can do tomorrow night unless someone beats me too it.
SkidMark
Post by SkidMark »
well it is seriously spaghetti behind there so these general views may not help. Let me know if you need more specific picys or to know which connectors are for what.
It's a bit dusty where Skidmark rides :!: ;) .
TBH Hotwire the wirng connections are pretty obvious as the connectors are one-way or same colour. You then just tidy them away as best as possible.
superbob
Post by superbob »
WD40 lots of and an old tooth brush thats what I would use if you can get some contact cleaner then thats even better. I really enjoy cleaning the electrics up behind the headlight on my mk3.
SkidMark
Post by SkidMark »
superbob wrote:WD40 lots of and an old tooth brush thats what I would use if you can get some contact cleaner then thats even better. I really enjoy cleaning the electrics up behind the headlight on my mk3.
don't worry its already on my todo list along with waterproofing each connector...
:D Oh it's his wiring, I thought we had discovered earthworm Jim's living room :lol:
andrew19
Bike Owned: 250 MK3
Post by andrew19 »
I have a few photos of wiring behind head light of my Mk3 but am struggling to work out how to attach them to a reply. If having problems in FAQ it says to contact board administrator - who might that be? Thanks
andrew19
Bike Owned: 250 MK3
Post by andrew19 »
Bike Owned: KTM 200 exc
Post by back off road »
Yep its worked
SkidMark
Post by SkidMark »
MK3 and AR are a bit different so be careful - knackeredMk1's advice is best - match the connectors and then just secure all the 'hanging' bits safely.
HotWired
Post by HotWired »
Thanks everyone, that should help heaps.
