engine numbers
engine numbers
does anyone know what the engine numbers are for mk 1 and mk2 crm250?
i got a mark 2 crm but when i checked the carb it has jetting for a mark 1.
i want to know if has an earlier engine or the wrong carb.
is there any difference between the engines?
Re: engine numbers
Engine numbers follow frame numbers - viewtopic.php?f=20&t=5282&p=32257#p32257
There are differences between engines most of which are small. Most important is ignition timing.
Re: engine numbers
blimey that was quick, thanks for that, i should get it running tomorrow, once i do i am going for full rebuild, do you know anyone who has an ignition switch/speedo/idiot lights?
Re: engine numbers
Knack is the forum GOD if he says it it is true it is , i am only an admin assistant and John is the brake GURU
FAQ section covers all things CRM
Jeram is covering the tuning section if it works( but i doubt it
if his idea works i will eat humble pie)
and set about tuning mine
Re: engine numbers
What BoR says isn't true I do make mistakes
The CRM FAQs section is well worth reading. viewforum.php?f=20
Jeram is in the process of making a CR/CRM engine which will probably produce quite a bit more power than the original CRM. A lot depends on how well executed the modifications are made and how reliable the end product is.
john7780
- Bike Owned: crm 250 mk2
Re: engine numbers
back off road wrote:Knack is the forum GOD if he says it it is true it is , i am only an admin assistant and John is the brake GURU
Jeram is covering the tuning section if it works( but i doubt itif his idea works i will eat humble pie)
Re: engine numbers
where should the engine number be?
Re: engine numbers
10 o'clock from the kickstarter shaft. Sticking out of the crancase.
Re: engine numbers
engine is mark one, frame is mark two, does it matter?
