Crankshaft seal aftermarket
- vag
- Bike Owned: CRM250 Mk2.2
Hi All,
Is there an alternative/aftermarket Crankshaft Seal for Mk2? According to manual, it's double sided seal 38*52*9mm, PN 91202-KAE-003.
Local Honda Dealer can bring original seal in 45 days (!), so I'm looking for other option.
Re: Crankshaft seal aftermarket
Hi vag, try leisure trail in the UK:
http://www.leisuretrail.co.uk/
Not sure what the postage price will be like to you but I'm sure they would get it to you in less than 45 days!
According to lings.com that number is supercede to 91202KAE004 and is £16.vag wrote:Hi All,
http://simplybearings.co.uk/shop/index. ... th=19_4462
Would be a lot cheaper, just measure you're s and duplicate.
- vag
Answer from LT:
[i]Hello,
Sorry we can not send to ukraine[/i]
Will try other options. :(
[i]Hello,
take your seal to a bearing shop... they should have what your after... just be sure to explain things to them such as heat and other engine conditions...
- vag
It was done straight away after seal was taken off from the engine. No success. :(
Today I found another Honda Dealer, they promised to bring what I need in 20 days max. Will hope for the best.
thats not bad... I just waited 14days for crank bearing in australia.. the time flew
