Once you start!
Once you start!
Started with the fork oil being changed, then the fork seals while it was apart, then might as well do the bushes! head bearings were done last year! then a new rear tyre, while the wheels out might as well grease the linkage, but guess what bearings f***ked so replace those! then it turns out the swinging arm bearings are the same so replace those! (and a thanks to the forum for pointing me towards the AllBalls XR400 Kit) oh nearly time to rebuild, bloodly hell the front wheel bearings are a bit rough! might as well replace the front and rear while I am at it!
Thats it no more this year, gonna ride it now frame coating and engine next year!!
Looking forward to the first ride though all those bearings should make quite a difference to the general feel of the bike!
Re: Once you start!
Welcome to the "Forth Bridge Owners Club"xander77 wrote:Started with the fork oil being changed, then the fork seals while it was apart, then might as well do the bushes! head bearings were done last year! then a new rear tyre, while the wheels out might as well grease the linkage, but guess what bearings f***ked so replace those! then it turns out the swinging arm bearings are the same so replace those! (and a thanks to the forum for pointing me towards the AllBalls XR400 Kit) oh nearly time to rebuild, bloodly hell the front wheel bearings are a bit rough! might as well replace the front and rear while I am at it!
No,she should be good to go, for a week or two now:D .
john7780
- Bike Owned: crm 250 mk2
Re: Once you start!
Re: Once you start!
A week!!! I want another 15 years from these bearings!! :D
[quote="fallenmikethebike"][quote="xander77"]Started with the fork oil being changed, then the fork seals while it was apart, then might as well do the bushes! head bearings were done last year! then a new rear tyre, while the wheels out might as well grease the linkage, but guess what bearings f***ked so replace those! then it turns out the swinging arm bearings are the same so replace those! (and a thanks to the forum for pointing me towards the AllBalls XR400 Kit) oh nearly time to rebuild, bloodly hell the front wheel bearings are a bit rough! might as well replace the front and rear while I am at it!
Looking forward to the first ride though all those bearings should make quite a difference to the general feel of the bike![/quote]
Welcome to the "Forth Bridge Owners Club" :lol:
Mike[/quote]
Mike[/quote]
Re: Once you start!
Wow! only a short blast up the road, but what a difference the work has made, bike picks up much smoother no more bad vibrations or grinding noises! well happy, can`t wait for the first ride out!!
