gearchange lever
- hondafanone
gearchange lever
help; anybody know of a gear lever that will fit a crm250ar leisure trail used to do them for 45 qd aftermarket poss a ccm? mine is a bit shagged i noted that the ar on ebay went for 1475 any comments
Re: gearchange lever
Look at board index/ F&Q/ what fits what, on this site.
CR 250 might be the answer ?
Lets just get out there, and trail it.
I have a feeling all the CR range have smaller diameter shaft.CRM3 wrote:Look at board index/ F&Q/ what fits what, on this site.
I think a YZ125 from the early/mid nineties (you would need to check) is the closest but there are no exact copies.
- hondafanone
ta w ot a speedy result thanks for your help ive had my ar for over nine years 2000 v reg one of the last . clocked 26km only ever had to replace f.pegs with i.m.s ones excellent. usual bearings amd swingarm spindle probs .kickstart worn easy to spot weld a heal on it.watch out for seized p.v cables .i run a standard f. pipe which will take the knocks and a dep rear for easy repacking.extra 15ml oil in forks helps with downhill feel.mugan cdi helps me keep up with crf 450 always been run on fuchs sinthetic and gearbox oil changed every 1000km original clutch original head and barrel.only trail ride with mates now but did the dawn to dusk once the wet one.regards to all and thanks for your help
