no spark again
Manual_kinguk
Bike Owned: Mk2
no spark again
Post by Manual_kinguk »
just read the post about no spark on a mk 2.2 and it seems like the pickups are the problems leading to this.but i have also noticed damage to one of wires on the stator windings behind the flywheel.but the bike starts and kicks out twelve volts so i can't see that would be another problem unless i'm wrong
Re: no spark again
:( Just too confuse fault finding, both items mentioned can, and do break down when they reach operational temperature.
Some one mentioned about applying a coat of "hair spray", as temporary fix, to rule the windings , in , or out.
CRaMer
Bike Owned: MK 2/2
Re: no spark again
Post by CRaMer »
hi there guys, just to give an update, I ended up buying the new stator pick ups, but still no spark. I'm confused as sh**. I've tested my CDI, rectifier, and coil on my other 2.2, and all works fine. could it perhaps be magnito/flywheel?
Re: no spark again
Very unlikely unless it has suffered physical damage and cracked the magnets :?: .
Manual_kinguk
Bike Owned: Mk2
Re: no spark again
i replaced the pickups and stator windings and that did the trick but my windings where damaged.try taking the flywheel off and giving it a good clean inside mine was full of brown gunky stuff which didn't help.
capt
Re: no spark again
Post by capt »
My CRM had no spark ,I thought it was the stator plate,overiding the cut out switch was the cure for my bike.
CRaMer
Bike Owned: MK 2/2
Re: no spark again
Post by CRaMer »
Hi there guys, sorry its taken so long to reply, was out of the country on business. just a quick update, I've mentioned that I bought the new stators, but still no spark, huh... but, if I unscrew the spark plug from the head, and then earth it, I then have spark. So this tells me that I'm not getting spark under compression/load. any ideas as to why I've got such weak spark???
Thanks a mil
Julien
