Chain Conundrum
Chain Conundrum
Some advise please gentleman...
I am installing new chain and sprockets. New sprockets are 13T & 44T. I have cut the chain to 110 links and at present with the correct amount of free-play (about 3/4in) with swingarm elevated to longest length between sprockets the snail adjusters are on setting 15 of 40.
So,
Can I shorten by one more link?
How many links do any other AR owners have with this gearing?
Regards
SkidMark
So,
Regards
SkidMark
Re: Chain Conundrum
Re: Chain Conundrum
OK Mike, thanks for that. I'm guessing you mean 'links' instead of 'teeth'fallenmikethebike wrote:Mark,as it's only possible to shorten the chain by 2 teeth, IMO, it would be better to run that chain for a while until some stretch has occurred, this also helps in stopping the tyre nobbles on the tread picking up the shock protecting plastic cover when the bike is reversed.
Re: Chain Conundrum
Well, no, if you look at your chain at either end, where the split link goes, you can't take out just the one tooths worth of chain, as you would be left with the link plates, and unable to rejoin the split link.SkidMark wrote:OK Mike, thanks for that. I'm guessing you mean 'links' instead of 'teeth'fallenmikethebike wrote:Mark,as it's only possible to shorten the chain by 2 teeth, IMO, it would be better to run that chain for a while until some stretch has occurred, this also helps in stopping the tyre nobbles on the tread picking up the shock protecting plastic cover when the bike is reversed.
MikeI wasn't planning on shortening the sprocket...
SkidMark
Re: Chain Conundrum
Mike[/quote]
OK I see what you mean - you actually end up removing two links, one 'inner' and one 'outer' in order to use the split link (which is an 'outer' link) to rejoin the ends.
Re: Chain Conundrum
Well, no, if you look at your chain at either end, where the split link goes, you can't take out just the one tooths worth of chain, as you would be left with the link plates, and unable to rejoin the split link.SkidMark wrote:SkidMark
Mike[/quote]
OK I see what you mean - you actually end up removing two links, one 'inner' and one 'outer' in order to use the split link (which is an 'outer' link) to rejoin the ends.[/quote]
Yes, I've done it myself, *&%$*- locks, and had to put in two joiners
