Bike now workin 100%!
Just a video i took today. As you can hear the bike is now running 100 %
http://www.youtube.com/watch?v=ILlAQ3GbRIc
99 HONDA CRM250 AR MUGEN
KTM 525 EXC SUPERMOTO 05
Re: Bike now workin 100%!
avva look here Mike viewtopic.php?f=6&t=5284&st=0&sk=t&sd=a
The main problem was dirty fuel and it had been left idle for about 10 months
Sounds good now
What gearing are you on
. I've got 14/40 on my SM wheels which gives me almost exactly 10mph/1,000 rpm on my Mk1 (lower 6th gear than other Mks).
Its curently running 14/42. It was running 14/38 when i got it but i found that was far too high geared. Im not too sure on what rpms im doing per mph. My next investment will be a trailtech computer so i can get a rev counter. Top speed is about 85mph
You're a bit higher geared than me. My 6th ~ your 5th.
Vapor is the one to go for with the idiot light back board.
- josh mk 2 crm
Hello
Next time your around plymouth give me a shout plz,
i need to see what a crm250 should run like!! i dont think mines running properly!!
Yep will do josh
