running power?
running power?
Hi all, just a quick question, im currently building a cr with a crm engine in, and its getting ready to be put on the road and in for its mot, just wanting to put a horn on it, however i have found a few live feeds with the bike running and they are only showing 2.65 volts, with the multimetre ( however this mulitimetre has been playing up and may be faulty), but even when revved up and wired up to the horn, it only makes the horn vibrate and not even produce any noise, unless you put your ear right up against it, (the horn is brand new 12v one).
So i was just wondering how you get your horn to work with no battery, just the magneto, which is just the standered crm one.I would of though tit would produce enough power to make the horn work?
Any help would be super
Re: running power?
Having said that, there really ought to enough power to run a horn.
Where did you acquire the horn you are currently trying to make work?
Re: running power?
I have had a non-working horn virtually every time I've rebuilt a bike.
1.) check that the multimeter is correct or just stick a 12v bulb across the horn terminals.
2.) (This has always been my problem) the horn is not adjusted corectly. There are various systems of adusting the horn but most involve some kind of screw and lock bolt adjustment. - Just fiddle with this until you get it sounding correctly.
Re: running power?
Hi, thanks for the replies, got given the horn when i bought the bike, like i say brand new and tested it on a good working battery and its spot on, so that should rule out the horn itself and the adjustment?
Think my best bet will be to get a accurate multimetre and see what power i am actually producing, but again saying that with the horn wired up, the small vibration it was given when connected wouldnt surpise me if only 2 volts was getting to it, im not sure, any more suggestions? il have anouther play tomorrow, thought it would power up a little horn no problems.
Thanks again
Jim
Thanks again
Jim
Re: running power?
Horn is fine as you tested across another power source. Problem is elsewhere.
Rec/rec
Rec/rec
Re: running power?
yep, tried a different second hand rec of a doner bike and still the same, so think il swap the stator plate over and see if it sorts it, any ideas how much it would cost roughly to get them re-wired?
Jim
Jim
Re: running power?
jim_CRM wrote:yep, tried a different second hand rec of a doner bike and still the same, so think il swap the stator plate over and see if it sorts it, any ideas how much it would cost roughly to get them re-wired?
Jim
- vilguy
Re: running power?
If all you want to do is power the horn, bung a small battery on it for the mot...
On my cr500 project the lighting system is a real pain in the arse and im going to have to wait for service honda to finish redesigning their lighting kit. And at £400 for it (thats with no actual lights..its just the stator and cover) its a bit on the salty side of FOOKIN expensive.
So temporarily ive built my own wiring harness with a 3 cell lithium battery pack which powers the HID headlight, horn, and rear lights for around 5 hours. This extends to around 3 weeks of continous running without the headlight on! (led's are great ;) )
Mind you can run a horn off a 9v battery pretty easily.
It would be a quick way of getting it through the mot.
Re: running power?
yeah i was thinking of maybe doing that, just putting a small battery in the air box or something, just for the MOT, think i will do that, cheers. I am deffinetly wanting a cr 500 on the road in the next 3-4 years, and going of that price i think il buy one done, or have no lights, thats just unreal.
Thanks alot for the advice
Jim
Jim
- vilguy
Re: running power?
i looked at buying one done, but getting a proper pukka one thats had everything done, your looking at between £3500 - £5500 for the best. ALOT of money.
Ive spent £2500 on mine so far and its still on the original steel frame. I have a crf450 frame that i will do the conversion with. But thats a way off yet.
Good luck with the mot bud.
Re: running power?
cheers mate, i will eventually get it in for its mot, i hope :)....
Hello again, bit of a update on the problem, I changed the rec for another good one and still 2.50volts, (rules out the rec at fault), i changed the whole magneto and stator for another one ( i thought this would deffintly fix it) still 2.50volts Rules out that as the problem :( soooo i was wondering wether it could be down to the cdi unit? maybe loosing power through that?, its the last thing i can think of as there isnt really anything else? What do you think? Any help would be great.
Jim
Jim
Re: running power?
where are you, testing the power from? it seams strange that you are getting low readings after changin everything. check the reading coming from the reg/rec this will tell you the 12v supply you need, or change the setting to ac and check the input for the unit, ground to earth. if your still getting low readings your replacemnet coil is also duff.
Re: running power?
Hi, ive just been testing it from the postive coming out of the rec, but also at all the other live feeds such as the lights, ignition etc, all reading the same, however when i first fitted the replacement magneto, i did get a reading of 5.50volts, but then later checked again and was just 2.50volts, il give it another run up when i have chance, and check all the lives for the voltage, like i say the cdi is the only thing i havnt changed, carnt see that effecting it myself though. Pretty sure it wont?
Jim
Jim
