waaahoooo - Swing arm bolt out in 20mins!!!
Well, there is something to be said for living in Africa and having no salt on the road...most likely this bolt has never been out before. I started soaking it about a week ago in penetrating lubricant and over the last week have disassembled the bike to get the rear shock out, then today I pulled the rear wheel and then had the swing arm bolt out in 20mins - just used a 16in long 1/2in drive breaker bar then drove the bolt through with a drift. Heres the bolt as it came out:
obviously the penetrating oil doesn't 'do excatly what it says on the tin'!!!
just mild surface rust that a wire wheel will sort out.
well, i'm off to do a bit more cleaning!
Regards
SkidMark
Regards
SkidMark
Re: waaahoooo - Swing arm bolt out in 20mins!!!
Looks good ,assemble with a good quality graphite grease and all will be okay. For real peace of mind drill the arm and put a grease nipple in.
will defo be putting a good quality grease in - thought about a grease nipple but decided against. They work well with bearings as there is a cavity to fill with grease but with a bushing the thicker grease doesn't tend to distribute over the whole contact area very well. Rather I will make sure I pull it out annually (remember I am in africa with no salt on the road) and regrease it. Will be worth me making a 'bullet' so I can remove in in situ without stripping everything down.MarkF12 wrote:Looks good ,assemble with a good quality graphite grease and all will be okay. For real peace of mind drill the arm and put a grease nipple in.
Regards
SkidMark
