mk3 rear wheel seals
i have searched the what fits what & can only find the sizes for mk1 rear wheel seals which are 25x40x7 x2 .can anyone confirm if the mk1 & mk3 use the same seals
thanks chris
thanks chris
Re: mk3 rear wheel seals
AR (which is probably closer to MK3) are:chris356 wrote:i have searched the what fits what & can only find the sizes for mk1 rear wheel seals which are 25x40x7 x2 .can anyone confirm if the mk1 & mk3 use the same seals
thanks chris
1 x 91252-KCY-671 - 25x40x7
1 x 91253-033-003 - 25x47x6.5
someone will confirm MK3 is the same...???
Regards
SkidMark
Mk1 is as Chris states. Mk3 is as AR, as Skidmark says.
thanks skidmark & nkmk1 i will call into simply bearings tomorrow they are just up the road from me
thanks chris
thanks chris
About the 25x47x6,5 seal,it is probably a honda product and very expensive from a honda dealer(cost me almost 18euros here in greece).25x47x7 will also fit,do the same job and cost much less.
hi kostas i used a 25x47x6 it cost me £4 for both seals from simplybearings.co.uk just fitted new bearings & seals today will see how long they last
thanks chris
thanks chris
