rear subframe?
rear subframe?
im thinking of choping up my rear subframe shortening it or just removing it completly has no real reason other than holding number plate brake light and a few other bits n bobs.
good idea or not???
just got my frame back from powdercoaters and looks nice!! swingarm going next but if not shure about this subframe what i want to do....
nick
good idea or not???
nick
Re: rear subframe?
So would you go for a BMW type of back mudguard ?
Re: rear subframe?
nah will still have a crm mudgaurd just chop back as far as posible cr's and other mx bike they dont go back so far ??
kernow krusty
Re: rear subframe?
Hi Nabz,
Most of the older Mxers didnt have the 'loop' at the back of the subframe. The 2 tubes just ended with a bung in each side. The loop just gives it a bit more strength, important if u carry a pillion. As long as you think the rear light/guard wont wobble to bits, shouldnt be a prob.
I did once cut up an old rear guard and fit it under the existing guard as a stiffener and that worked well.
Regards KK
Regards KK
Re: rear subframe?
ok cheers kk !!
will cut back loop out wounder how much that peice will weight ......
nick
nick
- Furnuts
- Bike Owned: MK1
Re: rear subframe?
not a bad idea KK i may do something similar to the front mud guard as on the highway i would swear it was trying to take into flight if i didnt know better.
