new member cr 500 engine
brady
Post by brady »
hello everyone has anyone ever fitted a cr 500 motor in a mk3. this is my second mk3 and think there excellent. thanks.
Re: new member cr 500 engine
If you are in the UK - Why fit a CR500 in a CRM chassis :?: You can register a CR500 and would get better suspension and a lighter bike. A lot of people have fitted a CRM engine into an MX frame because the engine is torquey, smooth and has six gears. It would require considerable work to fit a CR500 engine into a CRM chassis. It can be done if you have the skills but why :?:
The worst part of the CRM is the chassis. It's too soft and underbraked. This would be so out of balance with a more powerful engine.
If you need a CRM chassis to register a CR500 engine in a different country there are more reasons to do it but you will still suffer the same problems.
brady
Post by brady »
why beacause ive tried to register a cr and its a pain. i know crms are all about there engine/torque etc and are easy to ride thats why ive had 2. but you cant beat the power of a 500 2 stroke and i just thought it would take the hassle out of registering a motor cross bike plus you could always re valve the forks and fit a better shock. thanks for the reply anyway.
I know it seems like a good idea but believe me it is not unless you have all the skills and equipment and you are up to a 'project'. You need to be prepared to sacrifice almost all of the characteristics that make CRMs such good trail bikes and you will end up with something that is in no way competitive with today's enduro bikes.
The CR500 engine is the dogs in some respects, but it would be too brutal on the trail :!: . It would make a good supermoto but have you really thought about what you would have to do to make it fit :?:
NaBz
Post by NaBz »
im with knackered on this one!!
nasa_hrc
One Hit Wonder
One Hit Wonder
Post by nasa_hrc »
Hello all...i going to make the same move....a cr500 89-01 engine in a crm250AR ....i think the frame need some changes...and more.i hope i will have a good result...Its a Supermoto with CRF450 SM wheels,CRF swingarm and i think i will use a lectron carb about 44mm
As above plus other comments made elsewhere................
Have to say this is just my opinion ;)
