CRM250AR PowerValve - Ive had enough of these bikes...Almost
Hi All,
I have a 1999 CRM250AR. I am having Powervalve problems with it. I have read the huge post written by scrubbs.
Heres what ive done.
I pulled the servo apart and it all looks fine.. Attatched 12v to the motor and it spins no problems. I have messed around with the powervalve and it feels free and loose. I pulled the servo apart and measured resistance over the potentiometer.
I placed Neg on the far left of the three. I get 4.8-4.9k across the two of them next to the left. But if i put the neg on the right of the three the one in the middle (i think) gets like 0 and the one of the left gets 4-8-4.9k.
Think is. If i force wind the motor out a little bit.. Start the bike it winds it back automatically to where it should be? so im getting confused. When i rev the bike it just wont move.. wont budge..
Please help! Im at ends with this. Bloody honda.. Why couldnt they just use a mechanical system like everyone else.
Thanks,
Lyle
Pee'd off CRM250AR owner.. Preparing to strip and sell.. only 2500km on the clock.
Thanks,
Lyle
Re: CRM250AR PowerValve - Ive had enough of these bikes...Almost
corvid wrote:Hi All,
Thanks,
Lyle
Mate, I know excatly how you feel plus I had the additional problem of being in Uganda so sourcing parts is a big prob. I too followed the fault finding guide and was convinced my CDI had died but because I was so fed up I just splashed out and got a second hand PV servo unit, CDI and a new reg/rect. Just last week I installed the reg/rect and cdi then yesturday I ran it for the first time and guess what - PV still didn't move
My recommendation would be to buy those main bits and swap them out one at a time if you can afford it (you will always be able to sell the ones you don't need after) or ask for the asisstance of someone on the forum to swap bits between two bikes. Just remember that if you swap CDIs then swap the Reg/Rect too.
Hope this helps and let us know how you get on.
