Hi
Hi
Hi every on another member in north east london brouhgt my crm in dec she is now on the road t & T and is one of a few bike i have also have a FS1e and an RD 350 LC ypvs as you can see i like two strokes.
The CRM is a mk2 and when see runs i will use it but very unreliable at moment problems with starting but main issue is it keeps putting the temp led on as if it is over heating is there any way of testing the temp probe in the head and i think the starting is down to the kill swithch playing up is this normal
want to use it more any ideas please help.
Many thanks.
Many thanks.
many thanks
Jeff T.
Jeff T.
Re: Hi
jeftom,i've had a couple of kill switch issues with my mk2 strip,clean and lube or fit an aftermarket one is best solution. not sure why your overheating though
- woolley
- Bike Owned: AR
Re: Hi
as a combi boiler engineer i come across this problem a lot .the sensor is a thermister and if its had a bad overheat situation they tend to come on early take the sensor out and dip it in 85 deg water if led comes on its faulty (ps they can not be mended
