honda fmx wheels
- Manual_kinguk
- Bike Owned: Mk2
honda fmx wheels
so am i right in thinking that a set of honda fmx 650 wheels won't fit a mark 2.2 crm because the dommie wonts dont ahd there the same
Re: honda fmx wheels
definately not I had a set, the front will if you machine in the disc mount by 10mm.tricky.you might fit the rear but you have to do the same and i dont think there is enough meat to do it, +hub and bearing need to be taken in also on sprocket side .I've done similar work on other wheels and it worked but wasnt prepared to try on fmx wheels so I sold them to a friend with a dominator which were a straight fit for him.hope this helps.
- Manual_kinguk
- Bike Owned: Mk2
cheers for the help i won't bother bidding on ebay then.do u know wat wheels will fit a bit easier
