Carb' breather pipes
- petrolhead
Hi, can anyone tell me the original layout of the breather pipes on a mk2, on mine the pipe on each side comes out with a "T" piece on the end a thats it, should they be linked or do they link in with the over flow / drain off pipes in some way (they are missing too )
both vent pipes should be connected with a 't' and a third pipe from the runs over the back of the motor and exits through a little retainer on the frame just behind the rhs foot peg.ditto with the carb drain tube,the engine breather would normally go there aswell but if your using it off road some folk lengthen and re-route it towards the head stock
- petrolhead
