AR Carby Problem
AR Carby Problem
Went to start my bike after leaving it stood for a couple of weeks - turned on the fuel and it just p****s out of the overflow tube on the float chamber.
My guess is the floats are stuck, but anybody suggest anything else to check whilst I'm at it.
Also, if I loosen the hose clamps can I twist the carb slightly to get at the bowl without removing the whole carb?
Cheers,
Cheers,
Hiya mate, it seems me and you share the same problems
this happened to me last week, I would say your right in the float
assumption. Someone suggested me to give the float chamber a
small tap first, just incase they are stuck.
I think twisting the carb all way round will be slightly awkward
I'm not 100% certain but I don't think it will work but will only take
you a few moments to check, try the tapping method first.
by the way, after much faffing (on my belhalf) I Fitted the DEP!
scrubs,if its only doing it when the fuel tap is set to reserve its very doubtfull it'll be the float height,if it was it would overflow in the on position aswell.
sounds like theres dirt/debris in the bottom of your tank and when you switch to reserve its going straight into the carb and jamming the needle valve open(it doesn't take a lot!).you can either drain the tank and clean it(check the old fuel for signs of dirt) or fit a decent fuel filter or do both just to be sure,i've had this problem after stoopidly using an old fuel container!
simply unbolt the tap from the tank and slide it out. you can very carefully pull the filter off the tap. unscrew the sump off the bottom of the tap and remove the filter from there also. Now blow through the main pipe and the recessed (reserve) holes with carb cleaner. this should get all the crap out. In the Haynes tradition, instalation is the reverse of removal.
jon
jon
I cleaned it and it appears fine If I blow down the (tank end) teat with the tap removed I can feel air coming out in both posistions and but not in the off
position that would suggest that it was all ok...So I put it back together
and I still have the same problem - no fuel when set to on posistion
