Mugen CDI Vs Standard CDI *Dyno Charts*
Came across these and thought some of you would find them intresting..
2nd Gear
http://i17.photobucket.com/albums/b76/l ... /ecu-1.gif
4th Gear (the dip at the start on the standard was a dyno error)
http://i17.photobucket.com/albums/b76/l ... /ecu-2.gif
2nd - 6th
http://i17.photobucket.com/albums/b76/l ... /ecu-3.gif
2nd Gear
2nd - 6th
- purple rooster
- Bike Owned: Mk3 prospec
yeah you lose a lot of low end traction with the mugen.
However I was reading this article a while ago and there was a japanese
guy who had hooked up the two units and had a handle bar mounted
cross over switch for high power and traction mode, that would be pretty
nifty if they wasent so expensive considering they only cost around £150
or something when they were in production I would have paid that.
just seems a bit pointless to go to those extremes for a 2% increase and a major loss of bottom end power.i bet you'd probably get the same if not more of a power gain of the cdi just by fitting an aftermarket pipe.just goes to show 'dont believe the hype', i wonder if most people would still pay through the nose for one nowadays if they saw and understood that graph???
cheers scrubs you've saved me some dollar(presuming they made em for a mk2??)
