Lighting upgrades....
Are there any quick fix lighting upgrades for mk2 CRMS? drove it in the dark last night for the first time (back home from TRF meeting), very dissapointed would be an understatement!
Used main beam all the way and nobody noticed!
can you fit a more powerfull bulb? is there an after market light unit that doesn't look out of place?
thanks
Phil
thanks
Phil
- double_clutch
- double_clutch
yeah as far as im aware http://www.dirtbikestore.co.uk/acatalog ... s_144.html although its better to find out first!
Live Fast Die Young
Dont Drink And Drive, You'll Spill It
yeah the twin halogen lights look the buisness but they are poo at night
riding around the streets when there are street lights on its not a problem
try going out bush at night where there are no lights you might as well be wearing a blindfold as for putting higher wattage globes in a standard light you can do it but I wouldn't suggest it as there is no battery I have no idea what it would do to the power generating system you might blow a fuse or a relay. The light that my bike came with wasn't the standard one but it was bloody exellent it used a hella insert identical to one fitted in an 90's model audi it was extremly effective but bloody ugly and was heavy
I suggest you go and buy a twin halogen light because we all know that looks are important
Ports yellow and purple crm mk3
poo lights
cheers rikkster
\"IF YOU WANT TO BE DIFFERENT TO THE REST OF THEM, THRASH THE CRAP OUT OF A CRM.\"
- Thushara
I have fixed only the beam to my MK3 its very powerfull check this. This XR beam will fix to CRM.
Thushara
https://www.bajadesigns.com/bajadesigns ... ?login=YES
Thushara
