Grease nipples/ exhausts
- jackstribe
Hello folks quick question for you, have any of you put grease nipples on the rear linkage? If so where and how did you do it? also, have anybody got an FMF pipe on their CRM? If you have how much did you pay, and where did you get it?
cheers me dears
cheers me dears
Happy CRM'in !
I am about to grease me nipples on my swingarm and headstock. Simply remove the swingarm and drill a small pilot hole in the middle, and tap in a thread and insert a nipple. Make sure it doesnt go too deep (Most goto about 3 - 4 mm which is plenty) or the spindle will be obsructed by the nipple poking out of the inside of the swingarm.
May also do the bottom linkage aswell but suspect not as that is a doddle to grease anyway.
as for the FMF pipe, only one i know of is on my mate henrys MK2, and quite frankly was more trouble than it was worth. needed rejetting and never did run as well as the DEP. Sorry to upset you if you have just bought one but the DEP (apart from looking a bit bright) really are quite good.
Regards
Regards
- jackstribe
so basically, I just put nipples on the swingarm & linkage themselves, so when using the old greasegun, the grease will seep out the ends of the bolts/spindles? Looks like I'll get a Dep pipe then, I had got an FMF earlier in the year second hand, but i sold it as i was Skint!! Anybody know the cheapest place for the DEPS?
Cheers Paul for putting my List on the Site, looks good, will be sending a little update soon regarding my adventures with fitting a 91 CR tank to mine( Not such an easy fit as claimed by 15 yr old crm owner, as the mountings are different!!!) on the look out now for some secondhand 91 cr seat and plastics now. After that, maybe i should start to look at the sussies?!!!!
The prototype is getting along!! (maybe i should buy a CR rolling chassis!)
Happy CRM'in !
