Stop and start crm.
Stop and start crm.
Hi, just recently acquired a crm, thought it would be a brilliant bike to ride when 17, but the stupid thing keeps breaking down, one day it will start, the next it wont, ive had 3 different cdi's all known to be working, 2 reg rec's and still no fun. Had it running before, ran fan up the street then the next day not even a spark, any ideas guys as to what is up?
Stop and Start CRM
I had a similar problem on a MK 2 recently and it does drive you nuts, great some days start every time next day no spark, there were two problems :
1 The kill switch had an intermittent break in one of the wires, found whilst
using a meter and wriggling/pulling wires. took it apart and resoldered
on the switch. Even rang LT and they said even if it looks ok and has
been tested it can still be faulty, try a spare if you can get hold of one
2. The pick up points on the flywheel were rusty, these were then rubbed
cleaned and it now starts like a good un every time
MK3 SuperMoto (now sadly sold 04/08 )
MK2.2
MK2.2
- mikey11000
- mikey11000
Rightio, checked the kill switch, ran a current threw it whilst wriggling, no joy, had the flywheel off today and the pick up points are kinda rusty so going to give them a good clean up, gonna inspect the stator plate aswell, will keep updated as soon as above had been tried. Many Thanks
Damien
Damien
Honda crm250r mk2.
Peugeot Xps 50.
Peugeot Xps 50.
