AR Fork Seals
AR Fork Seals
Hi, just changed my fork seals today, easy enough job. I purchased the seals from BSL Brammer part No. NBR45X57X11A-DUO, they only charged me £10 each plus the vat.
A good way to fit the new seals without damaging anything is to remove and cut one of the the old one's, allowing you to open it up and fit around the leg. By lightly tapping against the old seal the new one's seated very easily. Because the old seal is cut, it can then be easily removed.
Hope this helps.
Next job is to change the exhaust back to the standard one, ready for the MOT.
Hope this helps.
Hi Mick, Its got a full RSV, sounds great !!! When I purchased the bike I was also given a standard full system and a new DEP end pipe, but have not got round to trying the DEP out yet.mickstoy wrote:nice tip john cheers
what pipe have you got on?
mick
I was going to put the standard one on today, but found a crack that needs a bit of welding first, its a bit battered but will do for the MOT.
The bike not registered yet, but i'm nearly there for the MOT and SVA test, then its just a matter of how well I fill in the paperwork!!! Then I can have some fun....
guys
iv got an rsv front on with a dep tail did you have to mess with the jets? mines good till its gets to the top then it seems as if its choking up a bit
i thought it might be because the pipes are mixed so was gonna just buy a dep front but its only gonna get bashed and as you know there not cheap
mick
mick
91 mk2
HONDA CRM 250 mk2 03/12/06.
RE-BORED----1st OVERSIZE.
FULL RSV PIPE.
AIRBOX----STANDARD, WITH BAFFLE AND RESTRICTOR PLATE REMOVED.
SPARK PLUG----B9EGV----(BR8ES IS STANDARD).
PILOT JET-50----(48 IS STANDARD).
MAIN JET-135----(128 IS STANDARD).
NEEDLE POSITION----MIDDLE----(MIDDLE IS STANDARD).
AIR SCREW----1 1/4 TURNS OUT----(1 1/4 IS STANDARD).
GEARING----13/45 (14/42 IS STANDARD).
These are my settigs at the moment Mick
Powers good all the way through the rev range
FULL RSV PIPE.
Mud, Sweat and Fear
91-MK2
91-MK2
John crm did you say sva test because crm's dont need them they can be registerd as enduro bikes you tell them about a crm's 900mm seat height which is the legal limit plus the 300mm sump ground clearance which is the minimum allowed then all you need is a standard MOT, reg doc's or owners papers money and forms for tax, and off to the VRO vehicle reg office you go.hope this helps and saves you money
