slashers wheels
slashers wheels
gutted, fmx rear wheel hub is too wide +front rim cant be repaired.I thought the hub was the same as the crm but it appears they used the crm mould but extended the brake carrier 5mm further out so it would fit but you need to mill off 5mm first( I'm talking about the front wheel).so its going to be cagiva wheels for me then.I also brought the fmx speedo drive it really is the same as crm, I will hope to use this on the cagiva wheel and wont matter if I alter it or brake it whilst trying to fit it.out of interest the speedo is the same on the fmx except no warnig led's (simple refit) with the bonus that it is already calibrated to supermoto wheels.
- abigsupermoto
- Bike Owned: MK3 CRM
using a tape measure the yolkes are the same as are the legs just the boots on the bottom are different,but the front isnt a prob like I said ten min's on a mill and hey presto the same as acrm .prob is the rear is to wide for swing arm.I still want the cagiva wheels anyway getting some wheel spacers done tomorow and bearings.
- abigsupermoto
spoke to enginer today instead of fitting front wheel in reverse as first thought for 40 quid he can drill the disk mount bolts through to the other side and make a mount bracket,bonus!having prob making final measurements before giving to engineer.if your interested the fmx hub ,rear wheel may fit your xl if its not a drum brake.
- abigsupermoto
