MK 1 Front Wheel Question
- flying scotsman
Took the front wheel off my MK 1 today and as I pulled the spindle out, a flat washer(not the tang washer that drives the speedo) fell onto the floor from the speedo drive side. Should this washer go between the outside of the speedo drive and the spindle or should it go in between the inside of the speedo drive and the wheel bearing. I had a look at wemotos parts drawing for the front wheel and it does not appear to show a washer, but then again its not the clearest of drawings to look at.
Any help much appreciated.
Steve
Steve
Hi,
I believe this is the illustration you looked at:
http://www.wemoto.com/library/crmfiche/02500000.gif
I have a mark 1 also and dont remember seeing a washer on the speedo side, will have a look tomorrow and post back if you have no joy.
SMB
SMB
