CRM250AR Crank Shaft Repair
Hi there,
I am based in Lincolnshire and am looking for someone to put a new con rod in the crank shaft of my CRM250AR as the big end bearing has gone.
Talking to Pete at Leisure Trail, he can supply the con rod kit with the big end bearing, but the guy they used to use for this has retired.
Can anyone recomend who I could try to get this done please?
Regards..... Ian
Regards..... Ian
Re: CRM250AR Crank Shaft Repair
These guys are very good. https://www.pjme.co.uk/
PJME, again would be my recommendation, i sent my Mk1 crankshaft to them back in April and they did a great job in under 2 weeks. All done via post for approx £90. They are well versed in dealing with the CRM webbed cranks and replacing big end bearing and balancing.
