Hello
Hello
Hello all,
I'm the recent new owner of a Mk1 on a G plate. I've been lurking in the background picking up information on rebuilding and lightly modifying to suit my ample frame.
I've fitted a pair of XR250 forks with slightly stiffer springs and I'm on the lookout for a Hagon shock to replace the tired original. I understand that Hagon no longer manufactures a shock to suit the Mk1 - can any one confirm?
I've also stripped the top end and had a rebore and replacement +1mm Wossner piston kit supplied by PJME, however I have hit a snag.... I bought a genuine small end bearing with the piston kit, but I've found it doesn't fit my rod. Would I be right in assuming the rod has been replaced and that I need a wiseco B1014 bearing? will that correct my issue and still fit my Wossner G-pin? or do I need to go on the hunt for a complete TRX piston kit etc?
Thanks in advance
Stuart
Thanks in advance
Stuart
Re: Hello
Just use the correct size bearing to match your Wossner pin to your TRX sized rod.
