Water pump
stumpotiger
Water pump
Post by stumpotiger »
My waterpump impeller has seized onto the shaft is there any way to free it as i need to removed the knackered plastic gear tia dan
Re: Water pump
What Mk do you have?
stumpotiger
Re: Water pump
Mk3 pal i also have a cracked plastic gear so if anyone has a spare id be very greatful
Re: Water pump
How badly is it cracked? Are there teeth missing/damaged?
Almost every CRM engine that I have taken apart has some degree of cracking. Unless it is bad then I would tend to leave alone.
