CRM250 MK2 replace MK1 wiring loom and Ignition system
rocky04
Post by rocky04 »
Hello everyone !!!
I have CRm250 MK2 cdi have damage ,pre-owner fix many time and now can not do anything, i have replace whole wiring system from MK1 ,including wiring loom,2 CDIs,condenser ,when i kick it there have spark one time ,anyone have try it before ? is the flywheel in MK1 same with MK2 ? i wondering the trigger on flywheel of Mk1 and MK2 not same then spark not correct.Thanks for your help
nicko
Bike Owned: Mk3
Re: CRM250 MK2 replace MK1 wiring loom and Ignition system
Post by nicko »
there is good information about the cdi and flywheels in the Frequently Asked Questions
viewtopic.php?f=20&t=5263#p59999
though it does not seem to mention Mk1 cdi/flywheel compatibility
CRM Mk3, billet clutch basket
The Mk1 and Mk2 flywheels are different and the trigger points on the crank cases are different.
rocky04
Post by rocky04 »
Thanks ,i have double check flywheel MK2 with MK1 they are not same trigger ,i will revise trigger on MK2 same Mk1 then try it out .
