Ignition coil ?
Ignition coil ?
Hi all bike wouldnt start this morning i think my coil has failed does anyone have the manual specs for testing this , it has recently been taking over a dozen kicks to start the bike but when it is started it runs perfect any help would be appreciated im getting pretty pissed off with this bike now
Re: Ignition coil ?
First to check would be to check where the ht lead goes in to the coil because they thinned the ht lead where it enters making it a weak spot , I changed my ht lead but you need some kind of silicone to hold it in place .
Re: Ignition coil ?
Is there a a low voltage circuit reading?
Re: Ignition coil ?
FMtB +1
Re: Ignition coil ?
These links are for the AR service manual but may help you and are handy to have , the first link is for chapters 1-13 the second is 14-20 , the ignition system is chapter 15
https://picasaweb.google.com/1169146523 ... 13Complete
https://picasaweb.google.com/1169146523 ... 20Complete
hope these help
hope these help
silver fox
Re: Ignition coil ?
Hi all
Still struggling with my AR, just checked the coil as the manual says. Primary coil measures 0.6 - 0.7 ( higher than the
manual says) Secondary reads nothing at all, with or without HT lead or cap. Does this mean it's dead?
thanks in advance
Ade
thanks in advance
Ade
- pudzie83
- Bike Owned: mk2 1992
Re: Ignition coil ?
cheap alternative for the H.T coil is honda h100's ones they work perfect i run one on mine and when my friends one packed up in wales he was more than greatfull i had my spare with me. I payed a few quid for both off ebay even new there less than 20 quid
mine is a mark 2 so not 100% sure if coils are the same across all models.
- baggins1984
Re: Ignition coil ?
Hi dave, quite strange this is the last post on the technical section because I've recently stripped and cleaned mine up including painting the frame but having got to the point of starting it I'm finding that the plug only sparks once in every 20 kicks roughly. When you take the plug out are you getting the same lack of spark?
I think I'm going to buy a cr125 ignition coil off eBay and see if that works. Let me know if you have any success and I'll do likewise.
