Rec/Reg Readings
frostoff
Bike Owned: CRm250AR
Rec/Reg Readings
Post by frostoff »
Just checking the regulator from the instructions on the FAQ page and It says 534 ish but my AR is reading 624-636-638 is this ok as I believe that the AR unit should be higher anyway??.
Re: Rec/Reg Readings
Check in the English AR manual in the FAQs. If the download is not available contact where you got the recent parts from.
