Mk2 motard
Mk2 motard
Hi all, been lurking on here for quite a while and have found a wealth of advise and tips so thought I'd share my Mk2 with you all. I've converted it using cagiva mito rear and aprilia rs front wheels, the suspension is coming out next week to be serviced and resprung so will hopefully handle a bit better after.
Anyways here's a photo for you all
l.
l.Re: Mk2 motard
Well done, looks nice- black and white
Re: Mk2 motard
Bit of an update for y'all, I was having too many issues getting the front disc lined up as I'm now running '93 CR250 forks for which there is no 320mm caliper carrier available. As a result I ended up buying a set of XR400 supermoto wheels and slotting them straight in with standard CRM discs and sprockets so everything is now working as it should! Also looks a lot better I think.
You'll have to excuse the rear mudguard as it's just a temporary fix until I sort something white out (vinyl wrap/paint etc)
