Clutch Plates
xstian81
Bike Owned: Mk3 CRM
Clutch Plates
Post by xstian81 »
The clutch on my CRM keeps sticking on, if left for more than a couple of weeks. I want to replace the clutch plates, steels and springs in an effort to try and stop this.
I've seen this kit.
http://www.ebay.co.uk/itm/150696906553? ... EBIDX%3AIT
I had a quick look on FAQ's and it says all clutch assembly's are the same between models. This kit is for a MK2 and the same kit is listed for a mk1 as well. I have a MK3 and I just wanted to make sure this will fit before buying and stripping the bike.
Does anyone else have anymore ideas on the sticking clutch? It's always done this in the 5 years I have owned the bike. I read somewhere cheap plates can make the steels rust and stick together.
Re: Clutch Plates
Should be fine but heavier springs mean harder to pull clutch lever.
xstian81
Bike Owned: Mk3 CRM
Re: Clutch Plates
Post by xstian81 »
That's a fair point, I hadn't really thought of that. Do you know of any better kits? I seen the spring sold separately, but not sure if they are heavy duty as well. I could just reuse the springs I have, the clutch doesn't slip, so I can't see it being a problem.
Has anyone tried this clutch kit, or heavy duty springs?
Re: Clutch Plates
As far as I'm aware (having tested the springs). Mk2 are the lightest, Mk3 are slightly heavier and the Mk1 has the heaviest of those I have tested.
The clutch set should in theory work with your original springs unless they cause your current clutch to slip.
Re: Clutch Plates
xstian81
Bike Owned: Mk3 CRM
Re: Clutch Plates
Post by xstian81 »
It only sticks when I first ride the bike. Once it has freed off, the clutch works fine, no slipping or notches. I think I'll buy the kit and see how much stiffer the springs are compared to my old set. I think I may have another set laying around somewhere as well. It maybe the case you won't notice when they are in.
Re: Clutch Plates
What oil are you using in the gearbox?
Re: Clutch Plates
Could be an older filling of oil contaminated plates as well as current? I don't imagine the oil that first gets into the plates is circulated much.
xstian81
Bike Owned: Mk3 CRM
Re: Clutch Plates
Post by xstian81 »
I'm putting Putoline GP10 in it at the moment. I've had the bike for over 6 years and it has always stuck on, and have used various light gear oils in it. Is this very common on CRM's. My brother has a MK1 and his sticks on occasionally as well.
Well I've ordered the kit and I'll report back. I might be a couple of months, by the time I've fitted it and had a chance to leave it, to see if it cures the problem.
helisupp
Bike Owned: CRM AR (4)
Re: Clutch Plates
Post by helisupp »
Its a funny thing mechanical objest.
I have 4 CRMs, was 5, and although all the same in every way, all stripped, cleaned and reassembled, same oil in each, only 1 stuck if left more than a couple of days.
Its nothing to do with springs, a new set of plates and clutch basket sorts every problem.............
Re: Clutch Plates
helisupp wrote:Its a funny thing mechanical objest.
+1, I would have thought all the heavier duty springs would do is push the plates together, harder :!: :!: :?:
Re: Clutch Plates
I don't think anyone is suggesting that the sticking problem has anything to do with the springs, heavy or otherwise.....
Re: Clutch Plates
My error, I was reading between the lines and I assumed that the referral to the springs being heavier duty was a pointer to that being the cure, rather than the kit as a whole.
The basket being in serviceable order, should allow the clutch to work correctly with the kit. I would have some cheap oil and flush the gearbox with that prior to fitting the new kit though.
xstian81
Bike Owned: Mk3 CRM
Re: Clutch Plates
Post by xstian81 »
I rebuilt the engine a year ago, so gearbox is clean. The clutch basket, although not new was serviceable with a little bit of cleaning up. I've ordered the kit now. So I'll do a comparison between the heavy duty spring, the original springs and a spare set I have laying around, to see which gives the best lever feel.
Hopefully the new plates will stop the sticking. I have a Laverda that sticks as well, but that will free off with a bit of gentle rocking. This never works with the CRM and sometimes the only option to free it off, is to ride it.
dillondog
Bike Owned: rm
Re: Clutch Plates
Post by dillondog »
a laverda, wow.
you should be use to having a bike in bit then if it was anything like my one.
I had a laverda 650 sport Kevlar and most of the time something wrong with it.
