hi about oil pump
- crm250aris
hi about oil pump
hi guys i bought crm250 mk3 on good condition.the first time stopped i pull the spark it was oily!!!i cleaned it start and now
it wont start!!CAN YOU TELL ME where maybe is the PROBLEM?MAYBE OIL PUMP ?how to adjust?
THANKS!!!
THANKS!!!
Re: hi about oil pump
There are many causes of what you describe.
First of all read the FAQs and particularly the sections on 'starting' and 'oil pump'
- crm250aris
the oil pump have an A mark and a line which of these two adjust? and always with open throotle right?
The line and open throttle as per the Honda manual section in the FAQs.
- crm250aris
Re: kick starter
hi again where can i find a kick starter for crm250 md24 1998 .maybe fits from another motorcycle?
This kick starter topic has just been discussed on another post. Try looking there ...............
BTW you won't find a kick starter for a CRM250 MD24 1998. The MD24 engine was used between 1989 and 1996. If you have a true 1998 bike it will be an AR which is an MD32. Any CRM kick starters fit any CRMs.
- crm250aris
its written md24 maybe if you can tell me from witch motorcycles kick starters fit?thanks
I'm sorry you don't get the point.........
If you have a question read the FAQs. If you don't find an answer there try searching for the topic you are asking about before posting. The forum members are a long suffering bunch and will answer most questions but not to those who obviously don't put any effort into finding an answer to their question.
Your question about kick starts was only asked three days ago by another member and comprehensively answered.
Lukep749 is asking the same question on the KICKSTART posting, have a look at the pictures and see if you have the AR kickstart.
- crm250aris
thanks i had read the post about kickstarts i dont have an ar kickstart .so a cr2000 and afterkickstart would fit.maybe from another motorcycle?
- crm250aris
