Side Stand Spring For MK1
mudboots
Bike Owned: CR500/CRM250MK3
Post by mudboots »
I know its a small thing but when my bike is 5.000 km away and my Thai wife dos not have a clue !
Its one of the things I forgot to measure up before my return to Australia, So anyone help with a good replacement spring off whatever bike that fits well for I can put it on the list of things I need to get.
cheers :)
Re: Side Stand Spring For MK1
Honda part no. 5054-MN4-000. Should be generally available.
mudboots
Post by mudboots »
Thanks for that Knackerd I went in to the honda dealer yesterday not much help at all here in Cairns QLD they only have parts listing for the AR and I was not sure if the side stand spring off the AR would be a good fit or not I will go back in this morning with the parts-number.
AR spring would probably do but not quite the right size/strength.
mudboots
Post by mudboots »
Thanks Knackered I went in with your parts number ... they said I was one number short on the first numbers they said there should be 5 numbers cross checking with the AR they said its the same spring for the XR250,400 so I said that will do thank you it's now on order.
